Not sure what you mean Rick, the rails are made of steel or cast and should only be out of place when wear occurs on the pivit points which are ecentrc bolts. There are adjustment bolts for each joint and if you are lucky the cast iron plates that anchor the cyl and pivit bar are still secured as left the factory. I will be glad to measure anything on my 47 for you.
