Column Shift Clip...
Enbloc
I'm looking for a replacement for the "c" clip that holds the column shift rod at the top of the column as indicated in the picture.
I can't find a replacement listed in the catalogs. Is there an alternative I can use?
Thanks
I suspect you will be able to find something similar in the hardware section of a brake parts catalog. If not...get a flat washer with right OD, drill to right ID, snip out a section and work it into there!
