Change distributor???
wga
Which distributor would be a good replacement for a stock Ford Load a Matic used on a stock (3 5/16 bore) motor??
thanks
If the load a matic is in good condition aand the rest of the engine is stock. It should work fine. It's when you change carbs and cams that the loadamatic stops working properly.
