The caster is built into the front end, providing you have a straight frame and front axel, and good front spring, when you connect the front wishbone to the bell housing it provides the correct caster. A bent wishbone will effect the caster; this simetimes occurs when someone jacks up the front of the A using the wishbone as a jacking point. The camber is also built into the front end by the front spindles; again a bent axel will effect the camber, as will worn spindle bolt holes in the axel.
Ron
