Carb secondary well
johnbuckley
On the Zenith carb what is the function of the brass secondry well ( A 9545). Why was it not deemed necesssary on the earlier Zeniths?:confused:
If memory serves the secondary well is supposed to help keep the mixture from leaning out when you open the throttle suddenly. almost same effect as an accelerator pump but not as good.
As for why it was deemed unnecessary, its more like it wasn't thought of before.
there were A LOT of inventions and improvements in the carburetor world from the 20s to the 60s.
Plenty of information on the Zenith at :
http://www.model-a.org/basic_info.html
No noticed any hesitation when accelerating with the early carb compared with the secondary-well carbs. Perhaps I'm running ir a trifle rich which would compensate for any weakness.
I believe the early Zeniths did have a secondary well, it was cast into the body of the bottom casting instead of being a brass insert. It would be interesting to learn why Zenith thought it necessary to later incorporate a removable brass well.
Tom Endy
Hi..can you explain in detail the carbon anode electrolosys as I have two very rusty zeniths to clean soon.
Thanks
Dennis L Oberer
Green Bay WI
