Backseat question?
Mr 42
When i bought the SuperDeluxe coupe, The rear seat was missing.
I got a lead on this seat but will it fit, the coupe?
The bottom part has a metal tag with 51A-706312044 on it.
The backrest has a tag with 21A-7066700-A.
51A would have originated around the end of the war in 1945 and designate 1946-47. 21A would be 1942 in origin. All are similar body types from 42 thru 48 but it has to fit the model 72 body type (coupe). The 46-47 models used the 51A prefix , back 51A-7260032 is basic assembly for the rear seat back, cushion 51A-7260080 is basic number for rear seat cushion assembly for 46-47.
Body type 70 would be a tudor sedan type. Both numbers you list are for the 70 type tudor but may fit with some work or modification. The 21A- number would have been to fit a 42 tudor sedan.
Kerby
Ok thanks, i was guessing that it was for a Tudor/Fordor.
I guess i can get it work, for me
