Russell Reay
After curing the starter problem, the car started right up, and I went for a test drive. Within 1/2 mile It was clear that the engine had very little power, and responded poorly to the throttle. Deal with timing first--Used the timing pin, located dead-on TDC with flashlight in the spark plug hole, all plugs look good, 6.35 V at both coil contacts and at points, condenser tests good, dist. body is good (2 of them), rotors are good, rotor gaps are a little variable, but have been for a long time, set the dist. cam timing per NuRex tool instructions and Paul Shinn video---won't start. Installed two different Zenith carbs and one Tilly. Spark lever fully retarded, throttle lever down a couple clicks, Gav open ~1/4 turn, choke works as expected, gas valve open--won't start. All I can get is backfiring thru the carb. Mayday, mayday, mayday.
