If you plan to put it on your Model A, you would be better off to bore a Model A intake manifold out to 1.3 inches. Otherwise the angle of the carb is slightly off relative to the firewall and choke rod. You can fix that with some offset bolts, but it is so much easier to just use the Model A intake.
