pooch Well-known member Jan 7, 2011 #1 I have a NOS rear axle. I notice the outside thread and nut are bigger than what is on the car. I presume this is a later axle. When did the thread increase in size and is this the only difference?
Ron in Quincy Well-known member Jan 7, 2011 #2 Pooch, I suspect the axel you have is not A; to my knowledge the thread size and special axel nut has been the same form start of production to end ? If someone has contrary information please correct me !! Ron
quickchange Well-known member Jan 7, 2011 #3 Pooch, they are all the same, have an AR rear here & its the same as later, Perhaps one you have has had thread stripped & been rethreaded, Derek from a hot dry NZ
George Miller Well-known member Jan 7, 2011 #4 The axle nuts are the same. So called AR axles did not have separate E brake lings, also the weld seem on the axle tubes was in different place.
pooch Well-known member Jan 7, 2011 #7 Many thanks all. It seems the axle still in car is 9/16ths, so must have been re-done when stripped. The 83 year old puzzle has another piece to add.
