Mac VP
The 3/4” tube only came in one length. It’s definitely a tiny bit smaller in diameter at the end that fits into the lower part end of breather stand. I recommend using a bit of lock tight at that location.
The inner baffle tube came in two lengths as noted above. I think the shorter of the two came on the vehicles with the factory aluminum intake manifold. The Green Book will confirm that. You cannot mix the two baffle applications, nor can either be easily modified to work in the other applications.
