another stuck engine tale
keith oh
Bought a 35 engine that had been stored in a damp shed for 25 to 30 years, placed it on my cheap Harbor Freight stand ( with home made side mount) and after cleaning around piston tops and valve guides, squirted penetrate on it all. I put a 18 inch breaker bar on the crank nut and jacked the end of the bar up with a small hyd. jack and piece of 2X4 so most of the engine weight was on the the crank nut. A couple of times every day I would squirt more Kroil penetrate on and with a piece of broom stick and hammer tap around the edge of each piston and on the valves to help vibrate the Kroil in. After over 2 weeks of this routine it broke loose. Oh happy day.
