funrunr
- City
- Belleville
- State
- MI
- Price
- $OLD
I have 4 Ford Slot rims. They are 15" X 6" these are very presentable rims and do have flaws. You can see in one pic I'm pointing to a scratch close to the valve stem and another pic I'm pointing to two small gouges (spelling?) on the very outter edge, these may be hidden once a tire is mounted on it. However I'm confident it will NOT be an issue (as in a leak). They do have other small scratches and nicks but the two mentioned above are the worse. These have the 5 on 5½" bolt pattern and will fit Ford trucks, F-1,F-100,F-150 and Bronco's from 1940 to 1996
and earlier 40-48 cars
These are very hard rims to come by and change the factory appearance quite a bit when I mounted them on my wifes Bronco.these will fit 4wd or 2wd the difference is in the center caps which I have other ones available
