Alternator wiring harness help
tjfl
Have a Model A with a 1976 Ford Courier engine and need help in wiring the alternator / regulator.
Alternator:
- Main post with white / red trace wire - goes to the main starter battery post.
- Small white wire (B) - to the same wire on the regulator.
- Small black / yellow trace wire (N) - to the same wire on the regulator.
- Small white / black trace wire (F) - to the sane wire on the regulator.
Regulator:
- Small yellow with blue trace wire - to?
- Small white / red trace wire - to?
- Small black wire - to?
- Short small blue wire with female terminal end - to?
Any help is appreciated, TJ
