9425 B inttake question
mikhett
I have a 9425 B inttake i want to putt on my 292.There is a tthreaded hole on tthe back of the intake near tthe disttributor.what is it for,if i dont put a plug there wont i have a vacuum leak???
If its on the left side, it goes to a power brake booster. Use a pipe plug. If you have power brakes, use a spacer under the carb so you get vacuum from all cylinders. Taking vacuum from one cylinder can cause a lean condition and burn a valve or a piston.
