8ba ?? id.
Randy Monroe
Hello out there I have a 8ba I think? It does have the correct heads and the dist is mounted on the upper top side Pass side..
offy stuff but looking at the rear of the block I see that the bellhousing is part of the block? I want to install a T5 but have not seen this app yet..
Yes Iam new to this flathead stuff there is not the 59 on thr rear and to change the clutch will need to drop the pan to pull the flaywheel if needed
Can someone help here
