64 t bird power windows
oldbugger
I usually lurk on the v8 side of this wonderfull site but now I have a ? about my 64 bird convt. The power windows used to work great then they started to not work once and a while, now they don't work at all. So i started testing, got power at the breakers on the fuse box but not at the main switch in the counsel. My wiring diagram shows a window safty relay. When I go through the test procedures thats where I end up, But I can't find it. Any clues would be appreciated. Thanks in advance
I see what appears to be a breaker above the fuse panel. That's looking at my shop manual for a '62-'63. There's not a good explanation anywhere for that breaker. May be entirely different for your car anyway! I've got to do some switch-window work on mine also. Good luck!!--Bill
Thanks for the info. My diagrams were not very detailed either. I think switch-window work goes with these cars. Thanks .
Once you have checked the relays and breakers, make sure the switches are good. The biggest problem with power windows from the 60's to the new cars I work on today is the switches.
Thanks for all the help, got a new relay all is good. Not a very nice place to get at, good thing my grandson has smaller hands. What is the function of the relay just under the power window relay?
