T texas webb Well-known member Jun 30, 2011 #1 I've got an 81 f-100 with a 300 6 cyl that over heated and died.It only has 0 to 30 psi on cylinders,Got a chance to get a running 6 from a 65 truck.Will my c-4 trans bolt up to the 65?Thanx.
C craig Senior Member Jun 30, 2011 #2 Your 81 should be a C6, the 65 motor is probably a 240, either way it should fit
D Dave72dt Senior Member Jun 30, 2011 #4 Compare the number of bolt holes on the bellhousing. There were some differences on V8s and may apply to the 6's as well.
