'59 Ford defroster hose source?
bobss396
Looking for this piece of hose that goes between the heater box and defroster plenum. Its oval and I can't find it in any parts house I deal with. Nobody online has a listing for it. If anyone can help, I'd appreciate it.
Thanks, Bob
if not if you have a store that make hoses they may have it or can get something that will work granted it will be round but that stuff is flexible
A while back I had a '59 Ranchero . I needed that piece also . I ended up using a piece of very inexpensive dryer exhaust vent flex hose ( from Home Depot ). I had to squeeze it into the right shape to fit , and secured it w/a hose clamp on the ends . Give it a shot !
Bob this may be what you want
Close but no cigar. But thanks to everyone for the help. I've seen some Jeep oval hoses that I can adapt.
Both the heater and defroster attach points are oval. If I get a hose that is too big, I'll make up adapters from some dense foam, maybe stack up some Dynamat.
I had the same problem with a 58 Ford heater and cut the top and bottom off of a black plastic oil bottle. As I recall it fit perfectly. Don't forget to take the paper label off the bottle.
I used the foil back duct tape that hvac people use on mine. Then painted it black. Not original but neat and functional.
wbedwards
don't bite my head of, but my 57 ch*** has a hose that looks like that, several dealers in calif that you can get a catalog from
Check with some of the after market A/C vendors (i.e. Vintage
Air). They use pliable duct material that might work.
