KULTULZ
Later heavy truck and HP FE/FT engines used steal shim gaskets (and this may be true of MD/HD FYB) and these also served the purpose of heat shielding for spark plug boots, etc.
I came across an engine build photo of the steel shim gaskets (B8T 9448-A) (1958/ 292 MD and HD) being used. You can see how they protect the plug boots from heat-
EDIT-
OK...
Let me try this again as I am constantly learning...
The photo shown is not using 58/ steel shim exhaust manifold gaskets (B8T 9448-A) but Spark Plug Heat Shields (B5A 12299-A).
B5A 12299-A Shield is available from Dennis Carpenter if cannot be found NOS.
Photos Below- 1st and 2nd photo showing individual shields and 3rd photo exhaust manifold gasket with integral shields.
2nd EDIT-
Relating to choke stoves. Photos Added.
Spark Plug Heat Shield _3 - B8T 9448-A Exh Manifold Gasket.jpg18.8 KB · Views: 6 -
CARB- Choke - Thermostatic Control 56-57 _2 - Service Repair Kit 9A761.jpg53.6 KB · Views: 3 -
CARB- Choke - Thermostatic Control 56-57 _3 - Service Repair Kit 9A761.jpg60.3 KB · Views: 3
