Jwawhite Well-known member Aug 6, 2024 #1 Anyone out there, how did you remove the upper Pod Nut? The ones next to the turn indicators? I cannot get a box on them for the Dash backing plate is almost up against the studs. Words of encouragement taken gladly.
Jwawhite Well-known member Aug 11, 2024 #3 Pulled the side and lower trim on Dash. Removed lower mounting bolts pulled Dash back and removed the upper nuts to the Pod. Geez what surprises to be had….
