Ok so we're way off your original gas gauge topic, what the heck, it's your thread and I'm successfully avoiding pulling a gas tank.
A month or two ago, I replaced the dist with a rebuilt '60s 292 dist off ebay. New points condenser, cap and replaced the coil. The resister looks new, and the dist is hooked to the lug opposite where the full 12V comes in.
I also bought a Pertronix setup, complete with coil, and I will put that on next, eliminating the resistor altogether.
If I ever get this thing done, I think I will write a book.
the gas cap is not vented either. When I took it off to check it sucked air,
So...is the gas cap supposed to be vented? If so, what size hole should I use?
The coil is polarity sensitive. It can act up if connected backwards, not sure why.
I figure the terminals wouldn't be labeled + and - if it didn't matter, might have something to do with the direction of the spark across the sparkplug electrodes...???
When 55's were new and 6v positive ground the '+' terminal was connected to the distributor wire for the points. When converted to 12v neg ground the wiring on the coil terminals needs to be reversed.
The '+' terminal should have the ignition power wiring connected to it and the '-' / 'dist' terminal connects to the points in the distributor.
The possible reversed wiring I previously suggested checking was the two different wires coming from the ign key switch & starter solenoid, that separately go to the ballast resistor and ign coil.
Yes the gas cap should be vented. Since yours isn't you could replace it with a repop '55 correct one, or make a hole as you mentioned. I'm thinking it should be really really small and somewhere(?) in the cap that doesn't allow gas to dribble out when the tank is full and sloshing around.
https://www.youtube.com/watch?v=y6ZAKtrCrfI
FYI, the vented reproduction '55 caps are recessed in the center, apparently to clear the emblem mounting hardware on the underside of the fuel filler door. (if that's a problem)
A book? We already have, it's in all these FordBarn pages. We just need someone to compile it.
I took the liberty of copying a previous post of yours that should help others reading this determine when a ballast resistor is or isn't needed with a pertronix ignition unit. The answer is...
'It depends on which coil you're using.'
I just got off the phone with Pertronix tech support, which answered my questions about resistors.
The instructions for the Ignitor state that if the car has a resistor, to use it with the Ignitor. The instructions for the coil state that if the car has a resistor, to remove it.
Per tech support, some cars come with external resistors, some have internal resistor coils. On old cars they sometimes get mixed and cause ignition problems. The Pertronix coil has an internal resistor, and therefore I should remove the original external resistor. If I had used a stock original coil with no internal resistor, I would use the external resistor.
How to check if an unlabeled coil needs/doesn't need a resistor for a pertronix module installation...
http://www.pertronix.com/support/tips/#a2
"What will happen if I leave the ignition switch on when the engine is not running?" (Poof!)
http://www.pertronix.com/support/tips/#a3
