Looking to add power steering to a 55 fairlane. Will a center link and piston and control valve assy. from a 59 Ford interchange? Also how about the idler,bracket and the pitman arm. Or do I need to change the Pitman?
I seriously doubt it would interchange after 1957 full size cars became quite a bit wider to accommodate the intro of the FE series engines and the cars were larger all around,1954-56's interchange. This would do the trick just bolt it on: http://www.ebay.com/itm/1955-1956-F...ash=item280f9dae15:g:JSMAAOSwa-dWldAi&vxp=mtr Or keep the manual steering and save on that gym membership
