52-53 power steering set up
BOSSY
UXBRIDGE
MA.
Price
$1000.00
I HAVE FOR SALE A COMPLETE POWER STEERING SET UP FOR A 52-53 FORD OR MERCURY. IT EVEN HAS THE VERY HARD TO FIND POWER STEERING CRANK PULLEY FOR YOUR FLATHEAD AND ALL LINKAGE AND CONTROL VALVE AND POWER STEERING PUMP WITH FLATHEAD BRACKETS. THIS CAME OFF OF A 53 FORD. IT WILL NEED TO BE REBUILT, ASKING $1,000.00 PLUS SHIPPING FROM 01569. OR YOU CAN PICK IT UP. EMAIL ME AT (rrbedard@verizon.net) Bossy.
Do the 4 hoses come with the unit and also the bracket with rubber grommet that mounts to the front cross member that two of the hoses go through. Is the power cylinder rod rusted or pitted? Do you have the special Rivnut part number 351633-S8 that is need to attach the idler arm bracket the the right side rail (frame).
Thanks,Charles
Charles the 4 hoses are their and the bracket with rubber gromet for hoses is their and the power cylinder is not rusted or pitted. The only thing that I don't have is the insert for frame for idler arm. I am sure you can come up with a insert for it. Thanks for asking. Ron B. (rrbedard@verizon.net)
