49custom steering issues
49flyers
New member
1949 ford shoebox on full right hand turn the brake cylinder hose is catching on the spindle support assembly causing the steering to jamb a bit and the left and right brake cylinders are different not a mirror image as I would expect them to be the hose on the right hand side has a cap between hose and spindle the hose in the left is touching the spindle and jambs on full lock leading me to believe it is not the correct cylinder for this model are there different types of cylinders for a 49 this is a righthand drive vehicle any help and insites will be much appreciated
