48 f2 rear end
i put a mid 60's 9 inch from a step-side pickup in a 51 F1, it boltes right up and the with was the same.
57 to early 72 ford 9 inch from an f100 has the spring pads in the same spot and the width will be the same. If you want 8 lug then go with f250 for the same years.
Also the F2's shock plates are 3", same as the '57-72 9" as mentioned. I don't have an F250 to measure, but should be the same or close for the plate.
