39 engine breaking up under load
Vanspeed
Have a 39 ford with a 21 a flatty in it. Idles good, revs up good but breaks up under load. Also likes the choke all the way closed, when opening choke, it still idles but dies when you hit the gas. Carb issue? Timing? What do you think. Single holley 94, stock motor.
The coil is 100, kit to put on a 20 dollar coil is 45.00. We'll see, I do have another engine that I can take the coil from to see if it changes.
VS,
You might want to check the point gap before spending any $$$.
Too wide a gap can cause what you describe.
Charlie ny
