'39 Brake / Clutch Shaft Large Bushing?
John Mc
Guys, apparently the large bushing for the '39 Brake/clutch shaft is a tough puppy to track down. My question is, does anyone know of an alternative such as finding the same bushing ID & OD, but longer?:confused:
John,check with geneshotrodparts.com.They supplied mine but is not N.O.S.They are hard to find.Gary
Hi, I called Stacy in TX and they don't have them either but did call me back after checking some other sources. They were truly nice to deal with but so far - no bushing.
Found my bushing from Terry at Little Dearborn in Minneapolis. Nice guy, I got the last one. Thanks to all who helped me find it.
If you measure the bore of the pedal and the diameter of the shaft, you might find a local bearing supplier can supply them.
I did this and after phoning a place that specialises in bushes, they sent me a couple FOC as a sample.
In my case it was not for 39 pedals, but it might be worth it, you never know.
Mart.
