Anyone out there ever removed the drain channel from a 36 Ford coupe? I'm not quite sure how to proceed after removing the 4 screws in the trunk area. I figured that removing these screws plus the single screw/fender washer on the inside below the window would allow the drain channel to "slip down" off the window track.
However, it appears that it may be spot welded in place to the window channel. Does anyone have experience in removing this drain?
