36 ford part what is this
Ohc Joe
36 Ford Sedan I have this plate where does it go what does it do was in a box full of Parts when I bought the car thank you
Ahhh shoot i don't have the other one
Anyone near so cal have one for sale
Or want to ship one out
909-455-68 too six
Does anyone have a pic of the driver side tin installed
Would this still fit in a 36 sedan with a 37 flathead in it ..
OHC joe
You should have no problems fitting the left tin with the 37 engine in your car, suffice it to say...in order to mount it, you will need to disconnect the steering arm from the steering linkage as the large hole fits around the steering arm, the will bolt to the frame rail of the car. Pretty easy to figure out the mounting once you get one!!!!
Does anyone have photos of these installed? I'm almost ready to get the front end of my 36 3 Window Coupe assembled and have no idea what goes where. Everything was in boxes when I bought it.
RockymountainSparky
At this moment, this is the best I can come up with. The right side one in this picture is hard to see it with the starter installed. The left one you can see fairly well and how the steering arm goes into the large hole in the center. IF memory serves me right, the left one bolts to the bottom inside flange of the frame and the right side bolts to the upper inside flange and fills the empty space around the starter. It should be pretty apparent where they fit as the right hand one bolts on with 3 - 1/4" bolts about 5/8" long and there will be three holes in your frame flange that match up. The left side bolts on with two 1/4" bolts (If memory serves) and again,should be quite apparent where once you get it over the pitman arm and slide it up into place.
RockymountainSparky
562490
