TomT/Williamsburg
I'm using a 36 Roadster rear window and my quetion is about installation. The outside piece has threaded hole posts for the screws and equally tall bumps or nipples inbetween the screwin posts. Here are my questions ....
Do I make holes in the material for the nipples when I pinch everything together? I would think so but I wanted to be sure ....
Do you use any clear silicone or (?) between anything to keep out water and such?
BTW, my window is heavy duty clear plastic, .020 thick I believe .....
Thanks .... I will post pics if needed ....
