35 Ford Water pump LOOK!!!!
Tony Martino
Kingston
NY
Price
$20inclshp
Pal Dave says it is 35 not 36t pal Charlie says he thinks it might be 36 Ford. Shaft looks shiny, turns easy. $20 including ship.
Re: MYSTERY 36? Ford Water pump LOOK!!!!
Tony,
It's a '35, not a '36. The boss in the casting for the grease fitting on a '36 is canted back toward the back of the pump.
Dave
Tony,
Dave
Thats good to know dave.I always thought both yrs came both ways. Thanks for the info.You can only get the pressure release grease fittings to fit on the 36 with out removing the pully which you cant do on the 35. ken ct thanks:)
Tony, it is a '35 wp as someone else mentioned. Take a wire brush to the sides. If you find a #48-xxxx it is definitely worth $20.00 as a rebuildable core to someone doing a restoration. Now, if you have a right side '35 wp core with #48-xxxx pn I would really be interested in buying it.
