Racur96
Putting the rear end back under my 34 and it had the stock rear spring u bolts still in place. Using the stock 10 leaf spring and rear end. The clamps or brackets that slide over the u bolts is what I’m having problems with. The ones I have are to narrow and the one set that fits stud spacing will only slide over the stud enough that the end of u bolts still in threads meet even with the bracket. Would anyone have a pic of the correct brackets? I have the nuts and u bolts . I believe the clamps I had here may be off of a 40. Thanks
