32 Pedals question (brake return spring)
chambies
I recently converted my 32 pedal assembly to hydraulic. I cut and rewelded the brake arm to the bottom of the brake pedal to line up with the 40 master cylinder that is mounted behind the k member. My question is where should I put the return spring. I bought both the regular stock style and a cross shaft brake return spring from Macs. I cant figure out how the cross shaft return spring fits into the assembly. Has anyone used this application or a picture would be very helpful. Thanks.
I took a 6 inch spring and put it between the clutch-at the top of the arm on the trans, and the brake master cylinder-where the master cylinder actuating rod meets the arm from the brake pedal.... Spring goes to clevis pins harvested from old Ford stuff, that has the nobs on the end, inside on the clutch, outside on the brake... Works for both If this is not clear feel free to contact me... Karl
