S Slicks Junior Member Dec 11, 2024 #1 How to remove drivers seat with adjustable track i can not get to the bolts to undo it at the floor does it slide of some how ?
4 400A Senior Member Dec 11, 2024 #2 It should slide off. It's the same set up as my A400. You might have to remove the adjusting mechanism from the bottom of the seat to allow it slide back enough to clear the tracks. It's been a while since I removed mine, but it does come off.
Vern Well-known member Dec 11, 2024 #3 This article is from the Victoria Association files. Perhaps it will help you. Attachments Victoria Seat Removal.pdf Victoria Seat Removal.pdf 432.3 KB · Views: 40
