Re: '31 Roadster Windshield Removal & Disassembly help - add'l questions
I was successful with the disassembly with the help I received from this thread - thanks.
However, as usual, disassembly has brought on additional questions.
I discovered that the pivot studs & frame cones on my windshield are NOT what's available from the suppliers.
On the removed ones, note the tabs on the frame cone that fit into the track on the side of the frame (where the weatherstrip goes); the recessed rectangular space in the cones that fits over the rectangular shoulder on the pivot studs; and the lack of the separate stud nuts. Any idea about these?
Luckily, those I removed are not damaged (except for needing the threads chased) and I should be able to reuse them
Another thing I noticed is the upper windshield post sockets in the stanchions seemed to have a paper lining (gasket?) that was significantly torn up on one side, and not much better on the other (better one pictured below).
Any idea on this? Do I need to replace it, and if so, with what?
As I mentioned before - the frame is chrome plated, implying Deluxe Roadster; but the dimensions are that of a Standard Roadster, i.e. the taller version utilizing the 13-1/2" Standard size stanchions, although mine are apparently polished stainless steel. Further, the windshield frame is drilled thru for the mounting of the vacuum wiper motor/blade (I think I saw somewhere that was done for the '28-'29?) - obviously none of this is original for the '31.
Again - any ideas?
My wife (whose father acquired the car in the early '60s by trading an antique shotgun for it) keeps telling me that it's a "Frankenstein 'A' ", with pieces and parts from wherever. Every time I go to fix/update/replace I begin the believe her more & more
