I hate to assume but with the one bulb head light I am assuming with low beam one filament lights and on high beam two filaments light up. Since the bulb can be rotated 180 degrees does it matter which filament is high or low?
Most bulbs are about 35/50 so it would make a difference. Just rotate the bulb so it corresponds with the light switch high beam. You usually can see the difference in the filiment but I always just looked at the light brightness
One filament (low wattage) lights up for the low beam and the filament is oriented above the higher wattage filament in the bulb holder. The high beam is centered in the focal point of the reflector. The higher wattage filament lights up for high beam. Both are not on at the same time.
I once installed 32-50 bulbs. The high beam (50cp) actually killed the running engine when turned on. I needed to readjust the generator but I replaced the bulbs to 21/32 which was faster that night. I now run LED pre-focused. What a difference! LRF
