Dick's Hot Rod Place
- City
- Houston
- State
- Texas
- Price
- 1099.
Sooooo, are you ready for something to replace your boring 4 barrel carb without removing the intake? Here is the answer in a custom 2 carb unit that will despense nearly 600CFM. The carbs are Holley 2110's, which have larger venturis, larger throttle plates, and 4 barrel style annular spray bars, resulting in more CFM that an standard Holley 94. Comprised of a Offenhauser adapter that converts your 4 barrel intake to a 2 barrel top. Then an early Ansen style slingshot adapter mounts the 2110's, connected with polished linkage, fed by custom fuel log, fuel pressure regulator, custom fuel pressure gauge, and all polished. Setting atop the carbs are chrome stacks with custom built polished risers with the same design as the fuel log, complete with washable foam filter units in each. The entire package is fuel ready adjusted and ready to use.
