29 Murray TS Back Door Hinges
wi0v
Alamo
Texas
So does any one have a set/pair of 29 Town Sedan back door hinges. Hinges off of a std fordoor may also work
Could also use the metal flashing directly above the drivers side back door top hinge. I was also told hinges from a fordoor Briggs might also fit.
One has part broken off and the other is badly bent. So the bushings won't help. However, my son is convinced he can make me a new pair. If that works, may get the bushings for the others.
Thanks for the help,
