21 Stud Flathead v8
skip86
Grand Island
Fla.
Price
99.00
Ok. here we go lets see who is paying attention out there,i have a 21 stud Ford flathead v8 block,the block is clean,it has fresh cam bearings in it,it has a crack in no2 maincap(not the block the cap)the crack is repairable,this deal comes with a reground crank that has a new gear on it,also included are the following things,2 stock oil pans,1 used aftermarket oil pump with pickup,(clean and very useable)2 early heads(the kind with the pumps in the head)2 waterpump cores,2 camshafts ,1 is new never run it has a new gear on it,the other is used and it also has a gear on it,7 used connecting rods,14 valves with springs ,guides,and retainers,oilpump cover plate with oilpump gears,8 used pistons with rings on them(rings are useable ,pistons are scrap,some retard tried to repair them by welding?,ok if your still reading heres the good part,8 new Silv-O-Lite flattop aluminum pistons with pins,these are brand new,and are .040 over,they wont work in this engine as i think its .060 over,anyway they are part of this deal,thats$99.00 for everything.cash when you pick it up,this block looks useable,with no visible cracks,i have pictures that i can E-Mail you,pickup only in Central Fla.i am not shipping this stuff,if you want you can call me at the house at 352-357-1763,if no answer leave a message.many thanks Ford Barn;)
