2 different 15"x 6" Ford car wheels
Lanny
Montevideo
Mn
Price
25 ea.
I have ONE good used (white) 15 x 6 stock steel wheel to fit '49 to '67 Ford car.
with 5 lug, 4.5" bolt circle,
and 2 3/8" center hole,,$25 + s/h.
Also ONE good used (black) 15 x 6 stock steel wheel to fit '68 and newer Fords
with 5 lug 4.5" bolt circle,
and the larger 2.75" center hole,,$25 + s/h.
These Fords listed below, ALL have the 4.5" bolt circle.
Ford - All 1/2 ton vans
Ford - All Granada, Monarch
Ford - All full size cars '49-'72; '79-'85
Fairlane '62-'79
T-Bird '55-'71; '77-'79
Mustang (5-bolt) '65-'73
Mustang SVO '85-'86
Maverick 5-bolt all
Ranchero '68-'84
Aerostar, Probe
Bronco II/Ranger, Explorer to present
Click on pic to Enlarge. :)
I can use the black one if it has the right offset. I am building a 51 Ford custom and it has 72 Maverick rear end, so I need the 2 3/4 inch center hole size. Can you put a straight edge on the front side of the rim and measure what the offset is from the center to the outside edge. Thanks, you can email me direct at smjfritz@charter.net I live in Lacrosse, Wisconsin.
Steve
