bobss396
You have to be careful here, because not all dual master cylinders have the rear axle plumbed to the rear, or primary port. It's very important to know how the master being used was designed to be plumbed, because rarely are the primary and secondary piston strokes equal in fluid displacement, even if the reservoirs look the same.
This is true. You have to know what port goes where.
