Patrick brophy
I am in the final stages of sanding ,getting ready to paint my baby bird.
While working on sanding the trunk deck while it is on a work table, I noticed when I would put some pressure on one side or the other, I could feel the trunk lid skin buckle. It would do the same on both side when I pressed down in the middle of the trunk on either side.
When I turned it over and looked I found that there was a gap between the pressed ,or stamped frame of the trunk body and the skin. There was signs of the trunk underside being sprayed with some type of rough coating, and the outline of the trunk frame was visible .There was a clear line that appeared to take the line of the trunk frame being tight up against the skin when it was sprayed.
Is this the normal condition ,or has the trunk skin become disengaged from the frame?
There is no damage to the trunk lid.
