- City
- WEST PALM BEACH
- State
- FLORIDA
- Price
- 22,000.00
PRICE DROP $19,000.00 ITS GOT TO GO NEED MY GARAGE SPACE.
GHOST FLAMES WITHIN THE FLAMES THAT ARE PEARL GREEN AND PEARL lite PINK PEARL ALMOST WHITE, YOU CAN SEE THEM IN THE SUN LIGHT REALLY TRICK PAINT AND BODY
THIS TRUCK HAS ALWAYS WON TROPHIES WHEN EVER IT WAS TAKEN OUT
428 POLICE INTERCEPTOR MOTOR BORED OVER .60 AND CAMMED
HAS OVER 400HP
C-6 AUTOMATIC TRANSMISSION
9"FORD REAREND 3.73 GEARS
CUSTOM CAMARO FRONT CLIP DONE BEAUTIFULLY AND CLEANLY
BRAKE MASTER UNDER FLOOR
FRONT TIRES ARE 255/60/15"
REAR TIRES ARE 33x19.50 15" MICKEY THOMPSON
TILT,TELESCOPING CADILLAC STEERING COLUMN
ALL GUAGES,TACH,SPEEDO,TEMP,OIL,VOLTS
C/D PLAYER INSTALLED IN CUSTOM MADE ROOF BOX
INTERIOR OF CAB PAINTED AND PINSTRIPED TO MATCH THE OUTSIDE
SMOOTHED DOORS WITH OPENERS ON THE BOTTOM OF DOOR
CUSTOM DOOR PANELS
ALL WINDOWS SOLID,THE FRONT WINDOW IS LEXAN AND HAS A COUPLE OF SMALL CRACKS
CUSTOM MOLDED FRONT FENDERS TO THE CUSTOM SMOOTHED COWL
CUSTOM CHOPPED CAB,SMOOTHED IN VISOR INTO THE ROOF.
CUSTOM STRETCHED AND PEEKED SMOOTHED HOOD.
CUSTOM CAB WHITE BENCH SEAT,DARK BLUE CARPET.
CUSTOM DETAIL ON BACK OF ROOF SIMILAR TO 58 CHEVY
CUSTOM MADE BED FROM FORD RANGER FILLED TAIL GATE
CUSTOM TANAU COVER PAINTED THE SAME AND PINSTRIPED AS THE REST OF THE TRUCK
TANAU COVER LIFTS VIA ELECTRIC SHOCK
25 GALLON GAS TANK
CUSTOM PAINTED SURF BOARD
CUSTOM ROLL PAN MADE FROM 308 FARRARI
CUSTOM WIDE REAR FENDERS 6"WIDER THAN STOCK
CUSTOM EXHAUST EXITS THRU RUNNING BOARD
CUSTOM PAINTED WHEELS TO MATCH TRUCK WITH TRIM RINGS AND WHEEL LUG COVERS
TRUCK HAS AIR RIDE ON THE FRONT AND REGULAR AIR SHOCKS IN REAR
HAS PUMP FOR AIR RIDE UNDER CAB, HAS GUAGE AND BUTTON MOUNTED ON BOTTOM OF DASH
CLEAR FLORIDA TITLE IN MY NAME AND FOR A 1956 FORD PICKUP
WORK ON THIS TRUCK WELL EXCEDES THE ASKING PRICE WHICH IS VERY LOW.
THE PAINT WORK ALONE IS VERY VERY EXPENSIVE THEN AD ALL THE CUSTOM METAL WORK HUNDREDS OF HOURS ON THIS TRUCK
CURRENTLY REGISTERED AND INSURED SO COME AND DRIVE IT BEFORE YOU BUY IT.BY APPOINTMENT ONLY
I AM SURE I AM MISSING A TON OF DETAILS JUST ASK..
561-389-8915 TEXT OR CALL LEAVE A NUMBER
HAS OVER 400HP
CUSTOM DOOR PANELS
25 GALLON GAS TANK
