poolplayer1
A few months back I had tried to replace the old one groove crank pulley with a 3 groove pulley to accommodate my new AC unit that I will be installing but when I did that,the pulley was hitting the top of the sway bar. Found out the engine was sitting to low.
Yesterday,I went ahead and made some changes to the motor mounts and that raised the engine high enough for the pulley to fit properly. Now, the engine is further back from the radiator so I need to bring it closer to the rad.for proper cooling. I can get a 2" fan adapter and that should bring it in within a 1 inch from the rad,which is where it was before.My question is this? Since I have the fan and rad.both out of the car right now and since I am going to put in the ac unit,would it be better to go ahead and put in a maybe 16" electric fan instead of the old mechanical fan for better cooling? For you guys that have a electric fan in your car,does the electric fan cool the engine pretty good? If not,I'll just go ahead and get the spacer and put everything back together.
One more question? I have a new radiator that I bought about a year ago and its a 3 row brass/copper type. Is this big enough to cool the engine down when using the AC or would I need a 4 row rad. Just trying to make sure that I will not have any heating problems when the ac is on.
Thanks for your suggestions and or opinions.
