kirkf
I have a couple questions about mounting the cab for my 1940 Pickup
1. Was there a rubber pad between the wood and the frame
2. Was there also a rubber pad between the wood and the cab?
3. Was there a rubber pad under the front mounting point at the firewall. (The spot where there is no wood)
4. What are the dimensions of each of the 4 bolts per side?
5. Is it correct that only the four corner bolts get a spring?
6. Does the wood used for the box also get a rubber pad under it?
I do have some original (Maybe?) wood from under the cab, and it had a double layer of rubber on both the top and bottom of the wood at the mount points.
Sadly I don't have original bolts and like most things for these trucks, they are no longer available from any of the online retailers
Any info would be appreciated.
Kirk
Kirk
