- City
- Ottumwa
- State
- Iowa
- Price
- 17,500
Hotrod/Gasser, new chassis engineering dropped I beam axle front end with disc brakes and power steering split bones pulled out to frame rails to add to the look. 55-58 chevrolet rear end 3.55 gear transverse spring with ladder bars all new shocks front and back, chassis engineering motor and ****** mounts, 350 sbc. .40 over double hump heads roller tip rockers 480 lift 282 duration cam tunnel ram with single 650 holley have double carb top that comes with it corvette finned valve covers Saderson full length headers, 350 turbo transmission shift kit 3200 stall converter B&M z gate shifter, new aluminum radiator new poly gas tank new Holley electric fuel pump new Haywire wireing kit new LED tail lights new VDO gauges new Speedway nostalgia hotrod stainless column nostalgia turn switch and 3 spoke wheel bucket seats with vintage seat belts, All new glass except needs door glass, 14x6 5 spokes front 15x8 Ansen slots rear all 4 new tires, running boards not on car for the look that was after but does come with a new set of fiberglass smooth boards, there is some insulation mat installed, the car has had some body work done handles shaved and is in grey primer with satin clear so it will weather while driven also has red pinstripe flames. Nice driver as is or drive as you finish. Email or phone 641-777-6334
