1936 rear quarter pivot window seal
Does anyone have a source for rubber seal for 1936 humpback rear quarter pivot window? Saw an earlier post where a 41-48 pivot window seal might work by cutting and joining two together. Are all the quarter window channels the same size and shape for a range of early fords?
Try Metro Molded Products. I used them quite awhile back. Although the rubber seal worked, i still had to add a fair am't of black caulk sealer on the bottom to complete the
sealing. I believe the seal I bought was only for the 36 Ford. I didn't like the idea of cutting
and rejoining a sealer from another later car. terry
Did end up finding the correct seal or did you use the 41 style and cut it??
Im working on this same issue
