If you are referring to the cylinder that moves with the ignition key to lock the steering wheel, it is held in by a pin on the underside. The pin is really a bolt with the head cut off. To remove it you need to drill it to pull with an easy-out. (never easy). Not fearing anyone ever trying to steal my car, I replaced that with a bolt with a head on it.
