CA Victoria
- City
- Templeton
- State
- Ca
- Price
- In ad
Thinning out some parts I will not need and duplicate items. Will add to it as I go thru a few more boxes.
Please reply with a phone #. If the ad is up they are still available
Will send photos not posted on request.
Not interested in shipping the large or heavy parts-best to have a friend pick it up for you.
1935-36 ford pickup cab corners and lower cab repair panel. New in primer from NW Classics. (Hand made & they fit well). $450.
1935-1940 lower splash shield. Nice original $100
1936 NOS Ford shock links (4) $100
1935-36 front fender supports- reproduction $50
8RT Water pump core casting and pulley only ready for a kit. $25
Brake booster-mid 50s to ? $50
1934-1936 exhaust manifolds very good $100
Heaterstat NOS thermostat with heater connection (2) - $200 pair
KYB rear shocks NIB #355015-22.36 extended (2) $30 pair
3 ea- Points set 18-12107, 1932-36 (Viacom) NOS -$35 ea
1937-1948 Water Pump Repair Kit, NOS Single Pulley -$20
1946-1948 ignition coil, NOS Wizard $80
1937-1948 dist. condenser NOS $12 ea
1946-1948 dist. condenser NOS $12 ea
1935 (early cab) pass. window frame $65
1935-36 pickup windshield frame, old chrome, missing hinge, sound but has a small amount of rust. $300
40-48 brake and clutch pedal mount base with master cylinder mount. NOS ford $40
8BA-8592 water necks: 1-Ford very good $15, 1-NOS repo $25
1933-34 crankshaft pulley. Older weld has Crack, needs repair $25
Open driveshaft trans housing, shaft, speedo gear $75
Model A Ford 4 blade fan hub & blades NOS $65
1934 pass - 1935-36 pickup vent screens, both have good screws: 1-original good $35, 1-repo frame needs soldering or spot weld $20
