1934 or 35 Ford hubcap strap
Ian NZ
Hawera
Down under
Wanted a 1934 or 1935 Ford hubcap strap only, for spare wheel locking cap.
Do you want 1934 or 1935? The 1933 and 1934 are the same but 1935 is different because the tire size is different, not only going from 17" in 1934 to 16" in 1935, but more important because the tire size goes from 5.50 in 1934 to 6.00 in 1935. This wider tire usually makes the earlier tire band chafe on the tire cover when a 1934 band is used on a 1935.
